No heat(Brrrrrrrrr)
jerry scharf_3
Member Posts: 419
use or borrow a digital camera, take a few pictures and attach them to a follow up post. It often is very informative even if you can't answer the questions.
jerry
jerry
NO HEAT(BBBRRRRRRRRRRRRRRRRRR)
I RECENTLY MOVED HERE FROM MN, AND MY HEAT WENT OUT IN MY HOUSE...THE FAN IS KICKING ON BUT IT IS BLOWING OUT COOL AIR..DO YOU THINK ITS A PROBLEM WITH BOILER AND/OR FURNACE? WHAT STEPS SHOULD I TAKE TO FIX IT W/O IT BEING TOO EXPENSIVE, IF ANY?0 -
A brand name with
a model and serial number of your unit would be a good start to any of us being able to help you. Also, just to make sure, do you have a furnace, a unit that heats the air, a boiler, which heats water, or a hydro air system where a boiler heats water and pumps it to an air handler which then blows the heat into the house.0 -
Big metal box wit a couple big metal boxes
or a boiler with black pipes and copper pipes ? do you have a gas bill or a fuel oil bill?
Or neither of the above?........:)
*~/:)0 -
I got to think if it was forced air....
she is as blue as the summer sky ,right about now .0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
