oil to nat gas conversion
Weezbo
Weezbo Member Posts: 6,231
or spectrum of why and why nots.
why not includes wrong boiler wrong nozzle wrong fire chamber wrong stack,wrong oil pressure ,wrong combustion air ,wrong stack temps to name a few....and the whys are at least as numerous starting with type of oil,..... oh , and equally unlikely to give you an answer.
in that the range is fairly large, and the newer modulating boilers are great at saving on fuel useage,you would want a more accurate answer that would be useful when considering your purchase.
Let me quick roll an example, place has two large boilers with a 125 gallon a day fuel habit. we size the boilers right change the stack ,add combustion air...now has three boilers whose combined thirst is 49 gallons a day same outside temps . you are better off with not going by what may be "There " perhaps it is way more than you really need.... there are a lot of good experienced individuals here ,someone may live nearby, should you be looking to change out your existing oil boiler and install a new boiler the correct size with the work done in a professional manner ,up to or better than, current codes, then look at Find a Professional on the left of this page.
then if one of the why nots lunges out at them, it would be sorted out in a flash and you would save a group of conjecture.... and Dollars in the long haul...
