Old bearing, anyone recognize?
D. McLean
D. McLean Member Posts: 20
is SAE 30 wt. Non-detergent motor oil. I thought about an additive to help prolong the life of the bearing. A replacement split-roller bearing is about $1800.00 wholesale. This school plans on geting rid of the steam and going to forced air sometime soon.
  • D. McLean
    This bearing is running alittle hot, seems to have issues with the oil wicking. I am gonna try to replace the wicking in the bearing, and see if that cools it down. Anyone worked on anything like this before? Shaft size is 4 15/16" (That's an 18" ruler, by the way)
  • rick_36
    rick_36 Member Posts: 19
    try calling bearing distributors at 518-274- 2550. they are very helpful .
  • Boiler Guy
    Boiler Guy Member Posts: 585
    What kind of lubricant are you using?
  • jerryb
    jerryb Member Posts: 113
    lube
    Try using (synthetcic)oil .One too many sam adams.
  • jerryb
    lube
  • Michael Rogers
    Michael Rogers Member Posts: 29
    Lucas oil stabalizer, we use it in all sorts if equipment including the racecar. Just use it unmixed, it will seem really thick but it works.
  • Kniggit
    Kniggit Member Posts: 123
    Have you ever heard of Energy Release? It supposely hardens the metal when it heats up and that will reduce wear, and increade efficieny, one time i saw a demonstration where they used a roller baring against a rotating steel wheel with engine oil and one with ER mixed with water, and they put weight to bind the parts together, the ER n water definatly had less wear.
  • powerhead
    powerhead Member Posts: 26
    Is that a Babbited bearing? It's possible the babbit material is worn and the bearing needs to be re-babbited and re-machined.
    Back in the day (before roller and needle bearings) this was a common task. You probabally couldn't find anybody capable of making a mandrel and pouring new babbit today though........
  • Paul C._2
    Paul C._2 Member Posts: 18
    GM Engine Oil Supplement
    is used to coat new camshafts to protect them during break-in and it mixes nicely with motor oil. Also, Hemmings Motor News lists several vendors who offer rebabbitting service.
  • Steve D._4
    Steve D._4 Member Posts: 22
    bearing wear
    David,
    If the bearing is worn the shaft will not build up enough of an oil film to support the load. Your best chance will be to rebabbitt the bearing. Also, the round portion of the shaft looks rusty, which isn't good. Is it possible to remove the shaft to have this section ground so it will keep the new bearing surface happy?
    Steve
  • Dale
    Dale Member Posts: 1,317
    Sythentic oil
    I too would try a 0w - 30 sythen. oil. I use Mobil 1 for everthing and have never had a problem. As to the wicking, if I remember the B&G course, the wick is a special wool that can't get charred or it won't wick oil up. And of course it must be kept pressed onto the rotating shaft. As the other posts suggested if the babbit is going get it redone before the shaft is damaged. The large elect. motor rebuild shops should know who does it.
  • Tony Conner
    Tony Conner Member Posts: 549
    You Can...
    ... get books on all kinds of old technology.
    www.lindsaybks.com/dgjp/djgbk/babbitt/index.html
