radiant heat underlayment for tile
Frank_9
Frank_9 Member Posts: 7
Has anybody heard of Schluter-DITRA underlayment used under ceramic tiles with staple-up heat below?
Thank you.
Frank
  • Mark_7
    Mark_7 Member Posts: 123
    underlayment
    We recommend some sort of underlayment or membrane so there is some movement for expansion of the different mat.Had a tile tech do a job and after some time the tiles started to pop,thinset didn't like the heat the membrane takes cae of that.
