radiant heat underlayment for tile
Frank_9
Member Posts: 7
Has anybody heard of Schluter-DITRA underlayment used under ceramic tiles with staple-up heat below?
Thank you.
Frank
Thank you.
Frank
underlayment
We recommend some sort of underlayment or membrane so there is some movement for expansion of the different mat.Had a tile tech do a job and after some time the tiles started to pop,thinset didn't like the heat the membrane takes cae of that.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
