Pipe Radiator and boiler
Jerry_15
Member Posts: 379
Probably 4x4 yellow pine for those decks and maybe the planking too. Great stuff, not so easy to come by now. It's all in the caulking that set's up the strength of the hull and the deck. If you're bunking below, be sure to have a few thumb-tacks and a bit of twine to take it to the bilge, instead of dripping on your head. Wet spots are over-rated (if they were ever rated at all). I was a shipwright in my last life, but ran aground. Good Luck
Muscles are stiff....
Here is the radiator in the pilot house of the Steam Tug Baltimore. And also a shot the Scotch Marine boiler that I was under grinding off rust. At the end of the day one is filthy dirty. Boiled water in the kettle on the coal stove in the galley.
I need some heavy copper or brass sheet to restore the sills of the doors if anyone has some cluttering the corners. And 3000 board feet of 4x4 to replace decking and a few thousand feet of pine tongue and groove board.
Steamhead, the smoke box needs lots of metal fabrication. The two furnace doors have been done. Coal fired, hand shoveled. I get tired thinking about moving that much coal by hand.0 -
Wow
looks like that radiator is made of brass pipe!
BTW- is there a gentleman named Steve Heaver involved with this tugboat?
I've seen it
Iv seen it on another tugboat at Two Harbuers , Minnesota and met a public work boss that have a key into the boat.. Really cool set and pipes just like the pictures... Do you have any outside picture of the tuggie?0 -
Yes, he is
Chief Engineer and Project Director.
And the web site is
http://www.steamtug.org
My Balmor place is walking distance to the Inner Harbor.0 -
Small world!
Steve is a friend of one of my good friends, Ed Grove, and as you may know is also involved with the Fire Museum. He has a LOT of steam power-related stuff at his house.... first time I went there I brought my Differential Loop with me ;-)
Ask him about his experience on the Mississippi riverboat.....
> galley.
Are you going to fire this old beauty. I would love to see it. I have worked on and fired some old traction engines and other stationary ones, but not a boat.0 -
That boiler sure looks similar to what I saw on "Dirty Jobs" when not only the host but the cameraman managed to worm themselves into the boiler.
FABULOUS brass coil radiator but presuming it's steam and presuming the close quarters I see from the photo I can't imagine it too high on the comfort scale.0 -
Great Photos
Doug, thanks for posting. I love old stuff ..
Scott
Sadly, the tug
is not running at the moment. Boiler is OK, has been retubed and derated from 150psi by the CG. Engine is also fine thanks to the many hours of the volunteers. The hull is the problem and fund raising is an ongoing project. Probably about 2 million to do all the necessary work. The Mechanical Museum is not very helpful and I don't think sees the importance of preserving this steam tug.
It may be better to give the tug to the non-profit group that has been working on it for many years so they can do specific fund raising since the current mamagement of the museum appears to have lost interest.
A shame indeed. By comparison, the Coast Guard is scrapping the 8 ships that are here in Baltimore after being taken out of service after 100 million dollars was spent lengthening them. Seems the good hulls are now no good and have buckles.0 -
I will try to photograph
the DC generator and water pumps steam engines. You can imagine the sounds in the engine room when the main engine and auxiluary engines are running, coal is being shoveled, the engine room bells are ringing for Full Ahead. The smells of hot lubricating oil and coal burning.
Oh the joys!!!0 -
is anyway that tugboat is related to
Edna G tugboat in Two Harbors Minnesota? I've been in it and its out of commission but the public works do fired up the boiler every once awhile in winter to thaw out their cold bodies in winter...0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
