cir. pump
The sytem pressure can not exceed the maximum prssure rating of the pump at 125 psi. system pressure, or system curve dicates net flow, and higher pressure on the discharge side unloads the motor, because no work is being done, or less work that is.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
joemat@taco-hvac.com
