cir. pump
Joe Mattiello_2
Member Posts: 94
The sytem pressure can not exceed the maximum prssure rating of the pump at 125 psi. system pressure, or system curve dicates net flow, and higher pressure on the discharge side unloads the motor, because no work is being done, or less work that is.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
joemat@taco-hvac.com
Joe Mattiello
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
cir. pump
Does a cir. pump on a hot water boiler work harder pumping at 20 p.s.i. than at 10 p.s.i. ? Thanks.0 -
Nope
it doesn't. The standing pressure is the same on both sides when the circ is off. The circ just causes a difference in pressure which makes the water move.
Circ Pump
Steamhead is right on the mark. A higher pressure increases the NPSHA (Net Positive Suction Head Available) on a pump, which can prevent all sorts of problems(cavitation) wth larger pumps or even a small pump in a marginal aplication.
RC0 -
With pump running...
increase in flo, Yes
Increase in head, Yes
Increase in Fric. loss, NO0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
