wall mounted wonder
Mad Dog_2
Member Posts: 8,273
Exemplary soldering job as well, love the cast fittings. Always a pleasure to see old-world craftsmanship. Mad Dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=210&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Here's a 6 zone gb with a 53 gallon indirect. We just used the end switch to fire the boiler on this multi zoned job, otherwise it would have been a room sensor location issue. Gotta love those EZ headers!
The last pic is a three zoned job I did a few months back that was actually a conversion from warm air to hot water baseboard (tried to push the idea of panel rads but customer did not like the look and was content with baseboard.) This was a rare occasion where I actually used the room sensor because I was able to size my baseboard around a water temp of 160 to accomodate for the max temp of 167 that is a default with the rc10. first floor was constant circ with the room control, and second floor had its own t stat to act as a high limit. Had to mess with the pins with the UBA and replace the snapped in half flame sensing rod to get it going but after the repairs it ran sweet.0 -
Boy Oh Boy
You are a busy guy Ray. All of your work is very professional. A pleasure to see!
Darin0 -
Thanks Darin so is yours!0 -
Nice work Ray
I like the draw-off for the expansion tank, nice touch.
Are those globe valves on the returns, and if so why ?
We use the thermometers on the return also and I like the added info while diagnosing.
Nice work.
Not sure whether I like the blue or white background yet.
Scott
Thanks for the comments guys! Matt for awhile there in the start of the heating season it did seem like a GB every week! I just now got my new computer up and running so I've got quite the little job picture folder going lol! I am starting a nice little 8500 sq ft house h/o had all the floors gutted so we can put in climate panel radiant, with two GB's one 79 gallon inderect tekmar controls infiniti for the a/c the whole nine yards. Scott I'm a fan of the black walls myself makes the copper stand out nicely! The blue board job I had globe valves which I mainly put in on the first two loops because they where a split loop and I wanted to balance the delta T perfectly. I love when I can buget in temp guages on the returns makes for a much easier job when it comes to balancing issues with loop temperature. Matt if I only had the time I would do every install with cast fittings a steel pipe looks so much nicer but when you've only got a day or two for the install, the torch and flux is a real time saver lol. I have sort of given up on pro press, we are not allowed to stock pp fittings on our trucks because of the expence, and I always find myself short a few fittings and having to switch back to sweat anyways. Plus I think you get a better looking job with sweat fittings, and imo it's easier to 'cheat' a sweat fitting if the pipe is cut too short (come on every does it! the old measure once cut twice!)0 -
SHHHH!!!!!
Ray, Don't give away our little trade secrets. I can't tell you how many times I have cut a piece of pipe twice and it was still too short. LOL!!
Darin0 -
Very nice................
soldering. Not too many guys can solder like that.
hbThere was an error rendering this rich post.
nice work
Keep up the good work. i like the oversizing on the baseboard. great job.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
