convectors and radiators
Jack Demczuk
Member Posts: 17
OK. I have posted here before and have made some changes to my system since and have a few questions. It started as me not getting enough heat in my bedroom. To begin, they system is working fine, i have low steam pressure, everything is insulated and all the convectors are getting hot, but still not enough heat in my bedroom. I believe that there was insufficient edr there. So i upgraded from cabinet convectors to Burnhams radiant radiators. They are all cast iron and wider than the copper convectors i was replacing. After a weekend of knuckle busting plumbing i finaly installed them. they get nice a hot, but somehow not as hot as some of the other convectors in the house. I have the edr book and can't find my convectors in there to do a comparison. Is it possible that a small copper convector would have more edr that a much larger, i mean five times larger cast iron radiant radiator. Look at pictures to see what i am talking about. Two of them are of the old convector one with and one without the cover, the last picture is of the new burnham. Thanks for any info.
-Jack
-Jack
> any info. -Jack
> any info. -Jack
Just a guy running some pipes.0 -
> any info. -Jack
"Is it possible that a small copper convector would have more edr that a much larger, i mean five times larger cast iron radiant radiator."
I would say not...Bigger is more, period. Look into vent sizes. Burnham will be able to give you your edr for that unit...
TimJust a guy running some pipes.0
