Steam/Oil Question.
brknrn
brknrn Member Posts: 2
I am trying to find out the maximum psi that is allowed in water/steam piping when using that piping to heat an oil tank.
  • brknrn
    Steam/Oil Question.
    What is the maximum pressure allowed when using steam/water piping to heat an oil tank?
  • Norm Harvey
    Norm Harvey Member Posts: 684
    Como say what?
    Im not sure I understand the question. Could you try re-wording it please?
  • RonWHC
    RonWHC Member Posts: 232
    The steam coil
    in the tank should be rated the same, or higher than, the the max rated boiler pressure on low pressure applications.
