Steam/Oil Question.
brknrn
Member Posts: 2
I am trying to find out the maximum psi that is allowed in water/steam piping when using that piping to heat an oil tank.
Steam/Oil Question.
What is the maximum pressure allowed when using steam/water piping to heat an oil tank?0 -
Como say what?
Im not sure I understand the question. Could you try re-wording it please?There was an error rendering this rich post.
The steam coil
in the tank should be rated the same, or higher than, the the max rated boiler pressure on low pressure applications.
