How to test a bad motor
I was wondering how to test a new beckett 3450 motor. They have the capaciator starts. I find people saying all the time about Ignitors and the new 3450 beckett motors that they either work or dont work. I believe there must be some way of testing the equipment because I know it goes bad. It just seems like the tech's I know kind of guess and check when it comes to changing Ignitors and new 3450 beckett motors. I have a little tester with a light that you set on top of an ignitor but I find this is not reliable all the time. If anyone could give me some feed back or information that would be wonderful.
  • Alan R. Mercurio_3
    Alan R. Mercurio_3 Member Posts: 1,624
    When you say new, do you mean the PSC Motor?
    Your friend in the industry,
    Alan R. Mercurio
  • Big Ed_3
    Big Ed_3 Member Posts: 170
    PSC Motor
    If the motor would not run ,I would first check the capacitor . If it went bad , most of the time all you have to do it look at it . A hole would be blown through . If not first check if pump is binding , then check the cap with a ohm meter . The resistance would climb up steady . A cap meter should also be used to check it see if it is still giving proper micro ferrets ...
  • Everything stated here already, all I'd add is get a motor you know is good, ohm out the windings and use those numbers as benchmarks for future readings on suspect motors. A megohm meter might be a good idea to check the condition of the winding insulation and try to wiggle the motor shaft ACROSS it's axis and see if there's any play at all, usually a little click. If there is that indicates worn shaft end bearings
