Radiant thermostat
...is single stage, non-programmable, and can be used with a floor sensor. Same footprint as the 512, too.
  • mikea23
    mikea23 Member Posts: 224
    Radiant thermostat??
    About a year ago we finished a 14,000 sqf home the entire home in radiant the flooring in the home is mixed tile and wood. The customer wants all new thermostats. curently there is a mix of wirsbo 511 and 512 stats they just refuse to learn how to adjust them. I need a simple stat that has a slab sensor for flooring protection.
    any ideas
    mike
  • ChasMan
    ChasMan Member Posts: 474
    Are those wirsbo 511 and 512 the same as Tekmar? The heat only ones are not exactly simple.. The heat cool one is a joke. Who wrote that software? And the three hour override, thats a good one.
  • If they have a slab house, tell them to stop adjusting the stats. might be worth a couple of visits to dial it in and let it go.
    yah, I know... fat chance. but worth a shot!
  • check dip switch
    the Wirsbow 511 & 512 are made by Tekmar and are identical.
    there was a large batch of them where the installer/user switch labeling was back to front so homeowners got about 5 more windows than they needed to see consequently making them think they are more complicated than they really are. (i had more than a few of them like this)
    the 508 is about as simple a radiant thermostat as you can get (just up and down) and like the 510, 511, 512 a slab sensor can be attached as well as an outdoor sensor to monitor the outside temp on your thermostat(cool!)
  • hr
    hr Member Posts: 6,106
    The Euro size drives me nuts!
    I like to have my wiring in a standard 2X4 electrical box. Especially when a sensor is needed, as it may need to be replaced some day.
    I wish they would make them the same size a the typicial US t-stat.
    The adapter plate looks cheesey and cost way too much.
    I feel better now :)
    hot rod
  • mikea23
    I run a scrap piece of pex up the wall directly behind stat and put the floor sensor in that goes in and out for simple replacement. has helped us more then one time
