I have air coming in underneath the thresholds. How do I stop it
Ericjeeper
Member Posts: 179
or under the threshold? if it is under the threshold, caulk it inside and out.
if it is between door and the threshold.. you might have an adjustable threshold plate.. is there a few screws in the center part? Mine all will raise and lower with a twist of a number three phillips screw driver.
Air leak
I have air coming in underneath the thresholds in 3 outside doors off of one room. How to I fix this.0 -
Short Term/Long Term
Short-term: Cape Cod Draft Stoppers (Probably in LL Bean or other country catalogs. Sort of long socks stuffed with fluff that you lay along the door.
Long-Term: Weather stripping with meeting thresholds on the sill and on the door. Fussy carpentry but worth it. Short of this a hinged door sweep. Works best when the floor is level; what fits against a closed door may not allow the door to open fully.
Good Luck and wear Uggs.
Brad0 -
Is there a specific name for that weather striping?0 -
No specific name
but generically it is known as bronze interlocking weatherstripping. Commonly it was done in the early 1900's, "let in" to all four sides of a door. Very precise.
Absent that, there are a number of vinyl or neoprene gasket door stop systems that can be had for less money but will not last as long.0 -
Thanks for all the insight.0 -
Take a look at "automatic door bottoms". Pemko is one manufacturer. Might solve your problem. If thresholds are not level then maybe not.
VT0 -
threshold caulking should be applied
to one side only. You need a route for condensation to get out. Best results are obtained with the air barrier on the warm side.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
- 17 Recall Announcements
