Munchkin Maintenance
Mark_46
Mark_46 Member Posts: 312
I own a Heat Transfer Munchkin 80M that was initially installed May 2006. It has served well through 2 heating seasons but it is due for maintenance/cleaning/inspection.
I am looking for a service provider that is VERY experienced with Munchkins and the cleaning/maintenance procedure. I am located in very northeastern New Jersey and would like to have the service completed before the heating season begins...which is around October 15th for my area.
I have looked through the ‘Find A Professional’ portion of this site but I can’t tell who in my area is experienced with this heater brand/model/type.
Thanks for any info/help in advance.
  • Darin Cook_5
    Darin Cook_5 Member Posts: 298
    Mark C
    Go the HTP website. www.htproducts.com and click on the find contractor link and enter your zipcode.
    Darin
  • EMB
    EMB Member Posts: 37
    Service
    Darin's right, the HTP website will tell you who has attended a training class. I'm not so sure it will tell you how experienced they are, so call and ask!
    Are you having some problem? I noticed you are looking for someone who is VERY experienced.
    If it's an annual service, we here on the wall can tell you which parts you should consider replacing.
    Enda
  • jalcoplumb_8
    jalcoplumb_8 Member Posts: 6
    Service
    What is your zip code? I am in NJ. I have been setting up and servicing Munchkins for about 9years. I also stock various Munchkin Parts for the 80-M. I stock blower units, igniters, flame sensors, gaskets, outdoor sensors, tank sensors, misc. parts. I also have a stocking supply house that I deal with that has parts in stock and can get them same day if the Distributor has them in stock.
    Jalcoplumb
  • Mark_46
    Hi Enda,
    Thanks for the reply.
    When I said 'very' experienced I had two things in mind:
    1. I dont want to hire a tech/service provider that would be looking at a Munchkin for the first time.
    2. An experienced tech/service provider being able to identify other problems/issues once the work is underway.
    Yes it would be an annual service. What does the part list look like for something like this on an 80M?
  • Mark_46
    Hi,
    Zip code is 07675.
