Square Ft. of steam
Boiler1947
Member Posts: 2
what does the terminology "square foot of steam" refer to
In steam the supply should equal the demand, or load. Now Pros. corect the wood guy if he goes off track. 1 foot of steam would be the amount of steam needed to fill 1 foot sq. of radiation?0 -
One square foot of Equivalent Direct Radiation (E.D.R.)
will emit 240 Btuh when there is 215-degree steam on the inside of the radiator, and 70-degree air on the outside of the radiator. The radiator manufacturer determines the square footage of each radiator, and the output in Btuh will vary depending on steam pressure, room-air temperature, or the temperature of the water, if the radiator is in a hot water system.Retired and loving it.0
- 167 Indoor-Air Quality
