steam heat
and post plenty of pics!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Keith_8
    Keith_8 Member Posts: 399
    get out of the boiler room
    Like Dan say's.
    Looked at a steam boiler replacement yesterday at a country club. This boiler is for heat only. 3 steam zone valves.It is 70* outside and this thing is cycling on and off trying to maintain between 3.5 and 6 lbs of steam. Windows are open and the zone valves are squirting some steam thru and heating the radiators.
    Measured the connnected load and the existing boiler is 3x larger than what they need.
    Insufficient combustion air, condensate feed tank dumping into the hartford loop above the water line.The existing boiler is about 6-8 years old with leaks between the sections. Should we assume it's not the manufacturers fault here? What a mess.
    Do you think there is an opportunity here?
    Thanks to Dan for the education!
    Keith
  • Brad White_43
    Brad White_43 Member Posts: 26
    Maybe they will hail you
    as a hero and give you a free membership as a bonus?
  • Keith_8
    free membership?
    Not likely.
    I'm not sure I could afford to tip the help.
    Keith
