Old steam system
Amanda Pipczynski
Member Posts: 1
I havent paid much attention to my steam system in the past and definitely havent been cleaning the low water cutoff as much as i should be, it is pretty plugged up. The system was at 24 psi and off on some sort of limit. Im not sure what i should do in order to clean the LWCO at this point and i dont know if it is a dangerous situation, any feedback would be helpful, thanks in advance
-Amanda
-Amanda
high pressure
Sounds to me like it would be wise to call a professional at this point? Have you tried the "Find a Professional" link at the top of the page? Dan has several informative books available if you click "Online Store".0 -
let's say
it's not a good situation. If you can find a handy pro with the find a professional, go for it. Otherwise, do you have any idea which limit the system shut off on?
I might add, too, that the pressure relief on the boiler should have opened before you reached 24 psi -- which suggests you have a number of problems which really need professional attention.
Where are you?Br. Jamie, osb
> in advance -Amanda
Bromley0 -
High Steam Pressure
I read your post & the pros replies to your post. The pros appear to be too nice to you. I do not understand. Maybe they have manners, or are just being civil & polite. I am not a pro, just a steam boiler owner like you. But you have a real serious problem! A possibly dangerous problem! An immediate problem! Do not walk to the phone to call a pro, ... run, run, run, to the phone and call a pro now! Critique my emotional response later, after you have a pro, or pros, in there. Bromley0 -
I'm With You Bromley.......
The other guys are just trying to be helpful, but YES!!!!!!!!!That is a bomb waiting for the opportunity to blow your house off its foundation.
PLEASE: 1) Shut stairway switch OFF
2) CALL a STEAM PRO - hopefully from this site
3) Wait for him
4) DO NOT RUN SYSTEM UNTIL THIS FIXED>
Mad Dog
what the result?
Haven't heard from her.... Sure hope she got a real boiler pro to take care of this dangerous condition0
