central heating radiator problems
phil_19
phil_19 Member Posts: 1
hi. turned heating on only rads upstairs working all down cold have bled system on drainoff and bleed screws on top of rads ,some rads seem to have lots of air bubbles when hose on drain off.
  • Timco
    Timco Member Posts: 3,040
    Need lots more info. Do you have zone valves or circulators? Sounds like either a failed zone valve or failed circulator. Is the system zoned? What pressure does your boiler read? Pictures of boiler & piping?
    Tim
    Just a guy running some pipes.
