Gas Furnace: machine gun noise.
Dean_17
Dean_17 Member Posts: 3
Hi,
My gas furnace caught on fire this morning. It is because the vents were not cleaned and the combustion went sideways causing a small fire. No damages. I turned the gas off and the electricity going to the furnace. When I turn the electricity back on, a loud noise, like a machine gun, goes off. What is this noise?
Thanks!
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    If no combustion and only electricity
    I suspect something fell into the fan scroll. The rapid regular cycling leads me to think this. Sort of like a .50 Cal M2, right?
  • Big Ed
    Big Ed Member Posts: 1,117
    cooked
    Could have over cooked the draft inducer as well... just follow the noise to the problem... Also sounds like a bad proven switch .The burner should not have fired with a plugged vent....Call a pro
  • Ted_13
    Ted_13 Member Posts: 40
    Furnace machine gun noise
    Does the unit have spark ignition? If so that's what it sounds like when it's trying to light
  • John T_3
    John T_3 Member Posts: 34
    Relay
    Could also be a control relay chattering. Regardless I hope you get someone qualified to come out and look things over for you. Sound like a dangerous situation.
  • Dean_17
    The noise seems to come from the front of the furnace. Looks like where the gas valve is.
  • CHARLES_4
    CHARLES_4 Member Posts: 61
    Furnace noise
    Turn off the light, go back upstairs and call the Marines. Machine guns can hurt you...
  • Flip
    Flip Member Posts: 40
    noise in furnace
    is it possible your low voltage wiring may have melted together causing a shorted circuit?
  • Dean_17
    noise furnace
    Flip:
    You are absolutely correct.
