Gas Furnace: machine gun noise.
Dean_17
Member Posts: 3
Hi,
My gas furnace caught on fire this morning. It is because the vents were not cleaned and the combustion went sideways causing a small fire. No damages. I turned the gas off and the electricity going to the furnace. When I turn the electricity back on, a loud noise, like a machine gun, goes off. What is this noise?
Thanks!
Thanks!
If no combustion and only electricity
I suspect something fell into the fan scroll. The rapid regular cycling leads me to think this. Sort of like a .50 Cal M2, right?
cooked
Could have over cooked the draft inducer as well... just follow the noise to the problem... Also sounds like a bad proven switch .The burner should not have fired with a plugged vent....Call a pro0 -
Furnace machine gun noise
Does the unit have spark ignition? If so that's what it sounds like when it's trying to light0 -
Relay
Could also be a control relay chattering. Regardless I hope you get someone qualified to come out and look things over for you. Sound like a dangerous situation.0 -
The noise seems to come from the front of the furnace. Looks like where the gas valve is.0 -
Furnace noise
Turn off the light, go back upstairs and call the Marines. Machine guns can hurt you...0 -
noise in furnace
is it possible your low voltage wiring may have melted together causing a shorted circuit?0 -
noise furnace
Flip:
You are absolutely correct.0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
