outdoor boiler reset controls
does anyone out there know of a stand alone boiler reset control with strap on indoor and outdoor sensors adjustable reset ratios and a single button/switch for bypassing the reset function, for a cost of 250.00 or less? I,m familiar with teckmar, taco etc. but they either plug into existing systems or don,t meet the above criteria.
  • dconnors
    dconnors Member Posts: 215
    I might have one but........
    I will have to check at home and see if I still have it.
  • why a $250 price point? Whatever you choose will probably pay for itself in efficiency gains.
  • joe_43
    joe_43 Member Posts: 1
    reset controller
    Have you looked into the Erie Boiler Boss 2400 outdoor reset controller? I've had one on my oil fired boiler for the last 8 years. Relatively inexpensive. Has worked flawlessly. See http://www.invensysbuildings.com/pdfs/F-27015-1.pdf
  • Mark_25
    Mark_25 Member Posts: 67
    Honeywell makes a nice one that does everything you want.
    Check thier website for application data. I got one for my boiler install and it was about $225 as I remember.
  • Jay_12
    Jay_12 Member Posts: 46
    tekmar 256
    Hello John,
    The tekmar 256 provides outdoor reset, comes with a strap on Boiler Supply Sensor, an Outdoor Sensor, and should come in at your price point.
    If you want to override the outdoor reset on the 256, simply wire a switch directly to the boiler thermostat connection.
    Jay www.tekmarcontrols.com 1-250-545-7749
  • Roger M
    Roger M Member Posts: 11
    Boiler Reset Controls
    Caleffi introduced a new one at ISH. Simple, low cost, and provides an input to bypass the reset based on either an aquastat for an indirect, or any contact closure that would bypass the reset. Also has a back lit display so that you can see it in a dark basement.
    Also thanks for the post on the Erie Boiler Boss 2400. I designed it.
    Roger M.
  • BillW@honeywell
    BillW@honeywell Member Posts: 1,099
    We have 3 models...
    the AQ475, which varies boiler run time to provide reset, the AQ675 that works with a 3-way mixing valve and an actuator, and the AQ775, that works with either a 4-way rotary valve or an injection pump. They are listed in order of cost and complexity. I would use the AQ675, with an appropriate 3-way mixing valve and actuator as the best value vs cost. We do not set the pricing...contact a local pro to get a quote.
