Hot Water Forced Air equipment
joe_66
joe_66 Member Posts: 30
American Standard
  • Tim Carrico
    Tim Carrico Member Posts: 2
    Hot Water Forced Air Handlers?
    Hi,
    Does anyone have any names of manufacturers of air handler/heat exchangers for hot water forced air systems,other than First Company?
    Thanks,
    TC
  • Brad White_48
    Brad White_48 Member Posts: 18
    EnviroTec
    out of Largo Florida has a pretty complete line, vertical, horizontal, direct and belt drive, DX coils, water coils, options for stainless steel casings and drain pains. Other features abound also. Variable speed too.
    While somewhat commercial/institutional in focus, their fan coil unit line, especially the CDV and CDH models work well in quality housing.
    http://www.enviro-tec.com/
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Just yesterday....
    I happened across Coil Company inc.in Pa. We're trying to nail down a heatloss, and they were the coil manufacturers.
    Whoda thunk? Chris
  • ttekushan_2
    ttekushan_2 Member Posts: 57
    heaters
    > Hi,
    > Company?
    > Thanks,
    > TC
  • ttekushan_2
    heaters
    a few more come to mind:
    Modine
    Airtherm
    AAF-HermanNelson
  • Bob Sweet
    Bob Sweet Member Posts: 540
    I.C.P is another one
    Heil in particular, has come out with a hot water fan coil unit, I believe it's an AXHW model.
  • John Mills_5
    John Mills_5 Member Posts: 952
    more
    ADP, Goodman,
  • Art M.
    Art M. Member Posts: 20
    Enerzone
    WWW.enerzone.com
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    There is a Comfort Air or Comfort Maker, something like that. I think that Homan's Asso. in New England sells them.
  • Greig_2
    Greig_2 Member Posts: 5
    H.W. air handler
    > Hi,
    > Company?
    > Thanks,
    > TC
  • Greig_2
    H.W. air handlers
    Lennox has a variable speed unit thats in a nice cabinet and quiet. Also the Crown is a another high quality unit. Greig
  • Confused_4
    Confused_4 Member Posts: 2
    Figuring out aquatherm heating systems
    I was recently told that my limited supply of hot water was because cold water was mixing in with my hot water supply. On a household aquatherm heating system (gas hot water heater) is there a valve that could be stuck or is there a pump that may not be working?
  • Brad White_50
    Brad White_50 Member Posts: 6
    You may want to post this as your own thread- it may get lost when tagged to this one (being on a similar but different subject). You will get more visibility that way! (And probably the right answer, too.)
