Hot Water Forced Air equipment
joe_66
Member Posts: 30
American Standard
Hot Water Forced Air Handlers?
Hi,
Does anyone have any names of manufacturers of air handler/heat exchangers for hot water forced air systems,other than First Company?
Thanks,
TC0 -
EnviroTec
out of Largo Florida has a pretty complete line, vertical, horizontal, direct and belt drive, DX coils, water coils, options for stainless steel casings and drain pains. Other features abound also. Variable speed too.
While somewhat commercial/institutional in focus, their fan coil unit line, especially the CDV and CDH models work well in quality housing.
http://www.enviro-tec.com/0 -
Just yesterday....
I happened across Coil Company inc.in Pa. We're trying to nail down a heatloss, and they were the coil manufacturers.
Whoda thunk? Chris0 -
heaters
> Hi,
> Company?
> Thanks,
> TC
heaters
a few more come to mind:
Modine
Airtherm
AAF-HermanNelson0 -
I.C.P is another one
Heil in particular, has come out with a hot water fan coil unit, I believe it's an AXHW model.0 -
more
ADP, Goodman,0 -
Enerzone
WWW.enerzone.com0 -
There is a Comfort Air or Comfort Maker, something like that. I think that Homan's Asso. in New England sells them.0 -
H.W. air handler
> Hi,
> Company?
> Thanks,
> TC
H.W. air handlers
Lennox has a variable speed unit thats in a nice cabinet and quiet. Also the Crown is a another high quality unit. Greig0 -
Figuring out aquatherm heating systems
I was recently told that my limited supply of hot water was because cold water was mixing in with my hot water supply. On a household aquatherm heating system (gas hot water heater) is there a valve that could be stuck or is there a pump that may not be working?0 -
You may want to post this as your own thread- it may get lost when tagged to this one (being on a similar but different subject). You will get more visibility that way! (And probably the right answer, too.)0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
