cast iron rads
I am in Denver and have many radiators. Let me know if I can help.
Dave in Denver
  • Heatman_2
    Heatman_2 Member Posts: 65
    cast iron rads
    Anyone know where I can buy standing cast iron rads for a one pipe steam system? I'm located in the midwest.
  • which one, what size?
    I have some in various sizes, I go to Des Monies to watch my beloved Wolves hockey kick the Iowa Stars' butts......
  • Heatman_2
    Heat loss of the room is about 8,000 BTU/hr. I am replacing a 6' piece of baseboard. Was hoping for something 38" tall and between 8" and 10" deep.
  • Brad White
    Brad White Member Posts: 2,399
    8.0 MBH
    Runs 33.3 SF EDR.
    A typical 38" High 3-column in the depth range you are talking about runs about 5.0 EDR per section. A large-tube type with 5 tubes per section will also run about 5.0 EDR per section. A 7-section if you can find an odd one would work but you may have to settle for an 8-section. That will run about 20 inches long, FYI at 2.5 inches per section.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • Heatman_2
    Yes , I am interested in buying a radiator, please let me know what kind of prices were talking about,
  • I'll messure
    Ill measure and see what I have for you when I get home
