knight won't fire
![[Deleted User]](https://secure.gravatar.com/avatar/a286b777013a82fb0a96d64122122145/?default=https%3A%2F%2Fvanillicon.com%2F5385664c61e6a76e78b466751687bd8c_200.png&rating=g&size=200)
[Deleted User]
Inside the cover, down to the lower left, there is a white PVC cyclindrical device. THis is the condensate trap. It has a float switch inside of it that if the drain outlet plugs up, will cause this condition. You should check the drain, possibly even taking a wet vac and attaching it to the drain to make certain it is completely clear. If that doesn't work, call in the installers to have them check it out.
ME
ME
My Knight won't fire. Saying \"SW clogged drain\"..........
I can't find a clogged drain! Any ideas???????0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
