Towel warmer
Do you have the access to pipe the towel warmers as its own zone of heat off the boiler?? If so, you can put a timer in the bathroom instead of a thermostat. This way right before you get into the shower (10 mins or so) you turn the timer on, heat up the towels and bathroom and then the timer shuts the heat down. This way there is no overheating of the room from someone leaving the thermostat on all day!!
Cowie.
