Oil Burner
Ed N.Y.C.
Ed N.Y.C. Member Posts: 73
IF you have to run overhead line still only need single pipe. If all connections are tight oil will syphon over from tank. Just bleeb pump and line till no bubbles are present. Have many jobs piped in this way. A tiger loop is overkill as far as I'm concerned. If your going to clamp line to joists make sure you have some kind of rubber around pipe at clamp sites. This will kill any vibration caused by pump gears. ED N.Y.C.
