Need Thermostat W/Humidistat
Uni R_3
Uni R_3 Member Posts: 299
http://images.canadiantire.ca/media/images/products/images/AirConditioningHeating/Winter/Thermostats/0522558_450_CC_437f3.jpg
I haven't used that function but it's there. Low end stat I bought for $30 (½ price) while trying to figure which expensive one i want to get, Tekmar, Honeywell or Proliphix.
http://www.yorkland.net/products/T200.php.
  • Big Ed
    Big Ed Member Posts: 1,117
    I am looking for a thermostat with a humidistat that could supply power to the humidifier from the cooling side of the thermostat.
    Hydronic boiler and the humidifier is installed and powered from the AC system...
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Here's a couple possibilities.
    Honeywell Vision PRO
    Totaline Intellistat
    Not sure what you by "powered from the cooling side of the thermostat".
  • carol_3
    carol_3 Member Posts: 397
    The Honeywell vision pro (TH8000 family) doesn't control a humidifier. One model (TH8321) can dehumidify, but only by overrunning the air conditioner. An air conditioner is a natural de-humidifier, which means you probably wouldn't want to try to humidify from cooling, because you'd be putting moisture in and taking it out at the same time, which would only tax the air conditioner and cost you money. The Honeywell YTH9000 family does control humidification, but you'd still not want to do it while cooling.
    Power doesn't come from a thermostat or humidistat because both of those are switches. When the switch is closed they allow power to pass through. The power to a low voltage humidifier of course comes from the low voltage transformer, by way of the thermostat--if it controls humidification--or the humidistat.
  • Big Ed_3
    Big Ed_3 Member Posts: 170
    VisionPro 9000 Series
    Looks like the 9000 series uses two terminals for humidifier with a set of dry contacts .I could use a jumper from Rc to one of the humidifier terminals , Which would solve my problem . I will verify to tech support tomorrow Thanks for heading me in the right direction .
    I picked up the Pro 8000 by mistake after miss reading the box . The box did say " dehumidification " ...
