Should the circulating pump on the boiler be on the feed line or
Buckeye
Member Posts: 11
on the feed line of a hot water boiler or on the return line?
On the supply
Pumping away from the PONPC. If it's existing job I find i much easier to move the Extrol rather than the circulator. As long as you are pumping away from extrol is the main thing.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Robert is right
I agree 100%.
The best of both worlds is to have the air separator and expansion tank at the outlet of the boiler just upstream of the circulator. Absent that, as Robert said, move the expansion tank to the suction-side of the circulator, no matter where it is. That will take care of 85% of the issues related to air removal and ongoing venting...0 -
> I agree 100%.
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
