Radiant
Jim_109
Member Posts: 45
Any comments, opinions, pros/cons and suggestions on the following;
Hydronic vs. electric radiant heating???
I am considering installing radiant heating under ceramic tiles in my bathroom. Currently the bathroom has no heat. The heated floor are is only about 15 sqaure feet. The entire bathroom is about 25 square feet.
According to one manufacturer, based on my projected useage and cost for electricity, my daily operating cost is about .10/day
A few electric advantages;
Parts and installation cost are much lower with electric.
Heats up quicker
THANKS! Jim
Heats up quicker
THANKS! Jim
Elec vs Hydronic
"It depends"
If you're in the midst of a whole heating system renovation, might as well go hydronic.
If not, the electric route is very attractive. I have a couple of "Heatweave" jobs done, and the homeowners are very happy.0 -
Electric
That's sounds good here. Then again, we don't have all the info. Will it actually heat the room? Is this the primary heat source? Is it only floor warming? etc.
Massachusetts
Do you have hydronic heat to tie into?
Do you have enough electrical panel/service capacity for the electric heater?
Electric pads look like they would not take up as much space as the tubes, heightwise.
Putting the floor heating in the bathroom on a separate controller is always nice. Few people complain about bathrooms being too warm.
You can always put the heat on a timer to reflect your occupancy to reduce the cost of running the system.
RFH is... wonderful.0
- 167 Indoor-Air Quality
