Solar and radiant integraton
how about
installing a seperate radiant panel for the solar, like a wall or ceiling, and you could run both systems at the same time. You could also use the solar down to about 90 degrees. Bob Gagnon
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
I've already got the tubing running under one floor of the house so I wouldn't want to add additional heating elements. I'm simply trying to supply the radiant floor loop with boiler and solar heated water but not at the same time and only to the radiant loop not to the rest of the high temp zones.0 -
re: Logamatic/solar
Sorry Cheftim,
Been overwhelmed recently. We ran the primary circ for boiler on the output for mix supply circ and turned DHW priority off for circuit 2 as we have solar preheated DHW (need boiler circ to run on a call for hi temp zones and DHW). Now the boiler will fire on reset but if solar is available the heat is not going anywhere so hours run will be cut dramatically depending on size of collector area and storage.
Best regards,
Eric0 -
it just seems
like your leaving a lot of low temp. BTU'S on the table. late afternooon, early morning, and some of the winter, you might not get your tank above 130. It wouldn't be that hard running pex to heat a bath floor or a floor in your living room. It's also a lot easier to make 90 to 130 degree water, making your panels more efficient. Bob Gagnon
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
