Pro Press still need a tourch
Just got my $2,000.00 worth of compact pro press set up for both copper and pex. Went to install a pex adapter on copper base board but needed a copper x pex 90. Called the supply house to see if it exists. They replied "DO NOT INSTALL COPPER PRO PRESS ON BASEBOARD RADIATION" that since the copper is thinner it will not work so you still have to solder on the adapter.
Other than that, the high cost of fittings and lack of fittings like mono flow tees or press ends on items like auto feeders (mass code no pex 12" heat source) I like my new tool.
Mitch S.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=388&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
