Indirect WH or not
Art M.
Member Posts: 20
In a propane fired boiler such as Munchkin, Trinity, Buderus, would it use less energy for DHW and heating(baseboard radiators)if it didn't use the indirect water heater?
Thanks
Thanks
An Indirect with a condensing boiler is more efficient than a direct fired separate water heater
AND...................
....an indirect will give you a much better rate of hot water production and delivery than a stand-alone water heater!!!!!
Starch0 -
And.....
to underscore the efficiency aspects, when you have two sources of combustion (one with a standing pilot and limited controls) you have a cumulation of inefficiencies. With an indirect you can use a timeclock, set up, set back and in general have, thermally speaking, a much tighter tank than one with a drafty hole up the middle of it.
And as Starch says, the production rate has no competition.0 -
Don't forget.....
Overall cost of operation,no need for another vent set up AND that you can buy lots of indirects with lifetime warranties.
It's a no brainer...Indirect hands down ! Chris0 -
Which is better of the 2. A trinity Ti150 with indirect or a Trinity Ti combo? The combo supplies all the hot water you need as a family without having to have 40 gallons of storage.0 -
Becareful with combo's
Treat them like tankless units. They have restricted flow and cannot supply concurrent showering/washing, etc. Many utilize a flat plate HX in the unit which could plug up over time. Nothing beats having a storage of pre-heated water IMO.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
