rad weight
jackchips_2
Member Posts: 1,338
to know the weight of something I weigh myself on a scale first and then pick the item up.
You may need a large scale-for the radiator.
Jack
Jack
OK...
We pulled all the rads from my rental today to have them sent out for sand-blasting. FOUR of us could barely move the largest ones. Any formula for rad weight? 3' high and 5' long? Averages?
Tim
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Just a guy running some pipes.0 -
The exact wieght is
> OK...
> Averages?
> Tim
> _A
> HREF="http://www.heatinghelp.com/getListed.cfm?id=
> 387&Step=30"_To Learn More About This
> "Find A Professional"_/A_
Rad weight
Based on Burnham's Classic Radiator weights, which is 77#/3 sections of 9"x30" high radiation, your 36"x60" radiator should weigh over 627#. Considering that todays casting methods use less iron than earlier castings, yours are probably much heavier than the current models.
John MacGregor0 -
Think...
... about sub-contracting the rad handling to a furniture moving outfit. My brother's company did it that way. They've got the guys who are used to wrestling pianos up and down stairs, along with all of the rigs & tricks to go along with it.0 -
Radiator weights
Personal experience has shown radiators come in 3 weights:
heavy, real heavy and OMG heavy.
Usually, your end will be heavier than the other end...0 -
I kind of think of it this way.
After picking up only one end of that thing, try to guess how many toe's on 1 foot you could possibly bruise or lose. Multiply that # by .23066 and then again by the actual number of toes that twitch when you think of that. Now,...Multiply one more time by the total feet you have to carry that puppy and that should get you close....;-)
Bottom line is thoes puppy's are HEAVY.....I hope someone smiled...;-)
Have a great weekend All
Mike T.0 -
Soo...no one else cares to 'weigh in' on this one?
T
Knowing how much they weigh will not help when it comes time to move them. We have have come up with several tricks. Here is just one of them.
Dave Stroman
helper
Not a bad idea, using the engine lift..
As my father always tell me if I want to keep my job, keep my hands out of the pockets and look busy... Have a carpetner friend told me that guys walking around with their hands in their pockets are the first to go...0 -
A common radiator as shown is 38" tall and 9" wide. Each section weighs about 38 lbs.
Dave in DenverThere was an error rendering this rich post.
radiator weight
Hi Tim,
Our beloved "boss", the founder of the old supply house where I work, used a chart for radiator weights based on the radiator's square foot rating. Basically it went like this:
thin tube radiators = 4.5 pounds per sq. ft. EDR
Aero or tube radiators = 6 pounds per sq. ft. EDR
column radiators = 7 pounds per sq. ft.
Example: a 10 section 3 column 38 high radiator has 50 sq. ft. EDR, 5 sq. ft. per section. So 50 sq. ft. times 7 pounds would equal 350 pounds
Happy lifting!
Best regards, Pat0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
