adding 3 furnaces to replace 1 furnace
Tom_35
Member Posts: 265
You could stay with a single furnace and consider providing automatic zoning for the 3 areas. Arzel Technologies makes an excellent zoning system that is designed for retrofit work. Any zone can call for heat or cooling as needed.
As far as how each tennant would pay their share, you can get data loggers that will monitor how often a zone receives heating/cooling---and then charge accordingly.
Tom Atchley
Tom Atchley
Separating Gas Service
Presently, I have a 3 unit building that has 1 furnace. I am contemplating the idea of putting in 3 furnaces along with 3 seperate gas meters. Does anyone have an idea about an estimate of a cost for this type of service? Also, there is 1 hot water tank and I would want a seperate gas meter for the hot water tank. cost estimate?. Aany suggestions? Thanks in advance.0 -
Where in the world are you?
are you
Are you talking about furance ( hot forced air system with sheet metal ducts) or boiler ( hot water or steam with pipings for raditaors) ?0 -
Pittsburgh. gas furnaces.thanks0 -
gas furnaces..not boilers or hot waer. thanks.0 -
I see
I'm at 99% wethead (pipings) guy and can't help ya much here but thinking how the sheetmetal connecting to all three units depending how it built... Good luck0 -
3 furnaces
it will be expensive since all 3 floors are tied to one furnace it would be cheaper to install 3 boilers and baseboard heat plus add 3 indirect water heaters so each tenant pays for thier own heat and hot water
Maybe not
If each floor has it's own trunk, then it might not be so bad. Would be nice to split the hot water though. Maybe 3 air handlers with 3 boilers. If the trunks are separate that would be cheaper than baseboard and it leaves room for A/C if that is in the cards.0
- 167 Indoor-Air Quality
