Press/ Crimping tools
If you do primarily residential, go with the compact. It will press 1/2 - 1" copper, and 11/4 , 11/2 Pex as well.
For the few occasions you may need the bigger tool, perhaps you can rent or borrow it from a supply house of another contractor.
It is much lighter, and smaller than the 330. Just so you know, the jaws are not interchangeable between models.
If your in a cold winter climate, don't leave it out in your truck. The cold will affect the hydraulics.
My $.02
Glenn
