Sticker Shock!
just
picture a ductless split product like Sanyo/Mitsubishi/Fujitsu, etc. Wall mount is most likely what you'd be looking at.0 -
Fuel Comparisons
Angela
This is a worksheet I made up a few months ago. I put in your usage of 1200 gallons and 76% efficiency that you claimed. I compared it to an 85% efficient boiler so you could see the differences. Assuming fuel rates unchanged, it shows savings over 1 year and 5 year based on different fuels, and different 2 different efficiency levels.
A couple of points to consider
1.) Future fuel costs are probably going to continue to rise, therefore your payback period would shorten.
2.) Cost of installation is not likely to go down, so if you elect to do this 2 years from now, you will have lost those years of potential fuel savings, plus likely pay more for the installation.
3. A more fuel efficient system would potentially make your house worth more - the tax man doesn't see this, but the potential resale value of your home could be somewhat higher if you intended to sell it in the near term.
The most important thing, be sure you have a capable, qualified contractor - he will be worth paying more for.
Hope this helps you in your decision.
My $.02
Glenn0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
