MBH ??Help
Scott Denny
Member Posts: 124
Steve
The Delta symbol can be found in Microsoft Word by clicking "insert" then "symbol" subset "Mathemathical Operations". Lots of other handy symbols can be found in the insert tables. For example: º,♂, ©,<,> to show just a few.
Please
Please, If a boiler is rated at 1233MBH
I interpret this as 1,233,000. I am sure this correct Just double checking. Thank you0 -
Yes
MBH in this industry means thousands of BTU's per hour, so 1233MBH is 1,233,000BTU/hr.
Have a lovely day.0 -
Thanks
I knew I was right just wanted to conferm Thanks Again0 -
an easy way to remember, and not second guess yourself is to multiply by 1000.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
joemat@taco-hvac.com0 -
MBH=
Jeff,
M = Roman numeral for 1000
B = BTU
H = Hour
1MBH = 1,000BtuH
FYI,
Steve0 -
And to expand on that MM
means "millions" (thousands of thousands). Also MM = coated chocoloate candy that one could eat in similar amounts. See? The Universe has Order! Except when it comes to cats.0 -
Steve
Yes I know, Simply a brain fart and someone else trying to confuse me Thanks Again0 -
Must be a form of tough love
Besides, Steve had to Google that
MM vs WW
Brad,
So the candies are really M&Ms.
I always that they were W&Ws.
Gosh, I just love to learn new stuff
the W&W
U can get them W&W at discount stores as they failed the quanitly control...
it took hours
I went to six websites before I figured that one out
In reality, a lot of us take for granted stuff that we throw out there. MBH, BTU, Delta-T (especially when we use that damn little triangle that I can not find the key for!), CO, CO2, ambient etc etc etc
Steve0
- 167 Indoor-Air Quality
