MBH ??Help
Scott Denny
Scott Denny Member Posts: 124
Steve
The Delta symbol can be found in Microsoft Word by clicking "insert" then "symbol" subset "Mathemathical Operations". Lots of other handy symbols can be found in the insert tables. For example: º,♂, ©,<,> to show just a few.
  • Jeff Elston
    Jeff Elston Member Posts: 289
    Please
    Please, If a boiler is rated at 1233MBH
    I interpret this as 1,233,000. I am sure this correct Just double checking. Thank you
  • Joannie_11
    Joannie_11 Member Posts: 45
    Yes
    MBH in this industry means thousands of BTU's per hour, so 1233MBH is 1,233,000BTU/hr.
    Have a lovely day.
  • Jeff Elston
    I knew I was right just wanted to conferm Thanks Again
  • Joe Mattiello_2
    Joe Mattiello_2 Member Posts: 94
    an easy way to remember, and not second guess yourself is to multiply by 1000.
    Joe Mattiello
    Technical Support Technician
    Tel. 401-942-8000 X 484
    Fax. 401-942-2360
    1160 Cranston St
    Cranston, RI 02920
    joemat@taco-hvac.com
  • MBH=
    Jeff,
    M = Roman numeral for 1000
    B = BTU
    H = Hour
    1MBH = 1,000BtuH
    FYI,
    Steve
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    And to expand on that MM
    means "millions" (thousands of thousands). Also MM = coated chocoloate candy that one could eat in similar amounts. See? The Universe has Order! Except when it comes to cats.
  • Jeff Elston
    Steve
    Yes I know, Simply a brain fart and someone else trying to confuse me Thanks Again
  • Brad White_70
    Brad White_70 Member Posts: 12
    Must be a form of tough love
    Besides, Steve had to Google that :)
  • Edward A. (Ed) Carery
    Edward A. (Ed) Carery Member Posts: 138
    MM vs WW
    Brad,
    So the candies are really M&Ms.
    I always that they were W&Ws.
    Gosh, I just love to learn new stuff :)
  • the W&W
    U can get them W&W at discount stores as they failed the quanitly control...
  • it took hours
    I went to six websites before I figured that one out
    In reality, a lot of us take for granted stuff that we throw out there. MBH, BTU, Delta-T (especially when we use that damn little triangle that I can not find the key for!), CO, CO2, ambient etc etc etc
    Steve
