temprise
don_163
Member Posts: 67
are you guys seeing with all the new high eff equipment?
I'm seeing saturated temps 15 degree above ambient.I'm also
seeing higher superheat readings then ever before.
Hmmmm....
And if I may change the subject...install a Trane gaspac yesterday and the customer was not too happy to see a piece of equipment that was bigger then her shed.
I do understand all about surface area and air being able to have more area to pass thru = better efficency.
I just think they could/should have done a better job on the profile.
Let see now instead of us working around the flowers and bushes..I see six foot fences in the future.
Your thoughts? Good morning!
Hmmmm....
Saturated Conditions-Superheat
Don,What are your indoor/outdoor temps and humidity? Have you tried plotting this system on a PRESSURE/ENTHALPY chart? P/E might be the "right tool" to help you figure out if you have a problem and where in the system it is .GOOD DAY!0 -
He'll Learn
I will be visiting Don and his group of fine technicians later this month to discuss just that.
We'll be spending a full day going over pressure enthalpy and a miriad of other topics...
It's gonna be a blast.... even the salad the night before.... Don't think I forgot, Don!0 -
And just know
going in, that its not polite to order anything that would
cause me to lose my manner and pickoff your plate.
Salad, very yummy!
Hello techman
It was a mild day inside and out and it was calling for a 26 degree superheat+/_.
As the Professor said he'll be coming to see us and about 12 days.Then I'll be able to do as requested and hopefully we all can share some reading and what we find this summer with each other.
P.E.!
Hi Don .You have yourself a deal!Soon!0
- 123 Chimneys & Flues
