Nortec Resdelux humidifiers?
Plumb Bob
Plumb Bob Member Posts: 97
Would anyone have any opinions or experience of Nortec Resdelux steam humidifiers? These are wall-mounted and can have their own blower for non-duct applications. They claim to collect all the sludge in bottles that are thrown away, but they still need both a water line and a drain line.
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    I don't have any experience with this model, but I have worked with their commercial products. Very nice equipment, though not inexpensive. The canisters are replaced annually if I remember right, which makes maintenance easy. Check the price on the replacement canisters so that you know what it will cost you to service them.
  • tom_49
    tom_49 Member Posts: 267
    And they need their own electrical circuit.
    Nice units. We have used them in the past. One thing I would say is ,watch out where you run the drain , it comes out HOT. Dont run it to a condensate pump.
    Like Paul says ,you will need to replace the canisters yearly.
    Another good one is the April-aire 1100.
    good luck, Tom
  • rb_6
    rb_6 Member Posts: 222
    Nortec
    We've had ours for almost 10 years...two thumbs up.
    Humidifier Install Photo
  • Brent_2
    Brent_2 Member Posts: 81
    nortec
    They are nice units. You can not use PVC for the drain line. I know when the NH units drain they also open a valve to dump cold water down the drain at the same time. You can use a condensate pump if you buy a special one made for high temp water.
    Brent
  • Ron Huber
    Ron Huber Member Posts: 121
    Resdeluxe
    Have used the NH several times with very good results. Have not had to change the cannisters that often. Most installed with Unico systems but a few with conventional air, have not used the stand alone with the blower pack.
