Nortec Resdelux humidifiers?
Plumb Bob
Member Posts: 97
Would anyone have any opinions or experience of Nortec Resdelux steam humidifiers? These are wall-mounted and can have their own blower for non-duct applications. They claim to collect all the sludge in bottles that are thrown away, but they still need both a water line and a drain line.
I don't have any experience with this model, but I have worked with their commercial products. Very nice equipment, though not inexpensive. The canisters are replaced annually if I remember right, which makes maintenance easy. Check the price on the replacement canisters so that you know what it will cost you to service them.0 -
And they need their own electrical circuit.
Nice units. We have used them in the past. One thing I would say is ,watch out where you run the drain , it comes out HOT. Dont run it to a condensate pump.
Like Paul says ,you will need to replace the canisters yearly.
Another good one is the April-aire 1100.
good luck, Tom0 -
nortec
They are nice units. You can not use PVC for the drain line. I know when the NH units drain they also open a valve to dump cold water down the drain at the same time. You can use a condensate pump if you buy a special one made for high temp water.
Brent0 -
Resdeluxe
Have used the NH several times with very good results. Have not had to change the cannisters that often. Most installed with Unico systems but a few with conventional air, have not used the stand alone with the blower pack.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 989 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
