buderus 115-34
Buderus makes this function really easy to use on the Logamatic.
Press & hold the suitcase (vacation) button then turn the dial to 13-14 days. When you return, the boiler will be back in its normal operation. Hopefully the summer mode;-)
Honestly, that equipment is so well insulated you won't lose more than a few BTUs 1/4º a day or less I believe. Hope this helps.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=296&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • jack z_2
    jack z_2 Member Posts: 15
    buderus 115-34
    I built a new house which I will eventually move into. Right now we are just there on weekends. The house has a Buderus 115-34 boiler, Carlin EZ1 burner, logamatic control, and a LT 300 hot water tank. Right now the boiler is in summer mode. If we won't be in the house for two weeks would it make more sense just to shut off the boiler. It seems like it would be a waste of energy to keep the water hot in the indirect tank for two weeks but I don't want to do anything to hurt the boiler. Any opinions on what to do in this situation. Thanks.
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    boiler vacation
    Use the vacation mode on the logimatic. I don't like to see any boiler go completely cold. Others may say shut it off and there are valid points to that arguement, but I would use vacation mode if it were mine.
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    NICE set up...
    You are there on the weekends keep it on as is...if you were away for a long time 2-3 weeks i would turn it off.kpc
  • S Ebels
    S Ebels Member Posts: 2,322
    Al
    I would agree with you on most boilers but I don't think it would harm the Buderus in the least to fire up from a cold start a couple times a month.
    If I were the HO, I would call the good folks at Buderus and get the opinion of one of their fine techs. They are very helpful.
  • Ron Schroeder
    Ron Schroeder Member Posts: 995
    Hi Gary,
    That's 1/4 degree per hour but it still isn't much.
  • Eric_25
    Eric_25 Member Posts: 79
    I have a 115-34 in my camp which I only visit once or twice a month with an indirect, I shut the boiler off when I'm not there from April thru Oct. I can't see the need to cycle the boiler once or twice a day to maintain the indirect. Some other manufacturers would not warranty the boiler under these conditions but you should have no problem with Big Blue.
