question for the wall
DanHolohan
Member, Moderator, Administrator Posts: 16,708
The Library keeps growing, thanks to so many generous friends.
Retired and loving it.
need help
Guys,
I'm new to steam heat.
Is their a problem with curtains touching the radiator?
Most say that it wont get hot enough for a problem.0 -
If everything's working right then you're fine...
If you've got spitting air vents you might have a problem with staining... other than that I can't think of a problem.0 -
Retired and loving it.0
Great article Dan
and I should venture off the "Wall" more than I do! I wonder if those old steam train "firemen" ever caught on fire? LOL.
Dave0 -
If you
stitch em to the floor, they can't catch on fire(G).0 -
You need 450 deg F to burn paper, so at the low boiler pressures you have, it will not get much hotter than 212, the boiling point at atmospheric.Drapes and curtains would need temps much greater than 450 to burn.0
- 50 Industry Classes
