Steam Air Valves
Jerry_20
Jerry_20 Member Posts: 2
Hello Dave, And thanks for the valuable advice. I will look into those valves you recommended. Good advice and I appreciate it! I love the mountians of Northern Cali...how far from wine country are you?...Regards, Jerry
  • Jerry_20
    Steam Air Valves? Help, please offer your advice...
    Hello Everyone,
    Would anyone be interested in offering advice or recommendations on -- 'What's the best choice for Steam Air Valves for a one-pipe steam system?' The manufacturer or type would be helpful.
    My goal is to have all the same valves on every radiator in the house. Your help is much appreciated, so let me thank you in advance for any feedback...
  • Dave Stillwagon
    Dave Stillwagon Member Posts: 1
    Steam Air Vents
    Hello Jerry,
    One of the most common steam radiator steam vents for one pipe systems is the Hoffman No. 40. Also you might want to consider the Heat-Timer Varivalve (adjustable) available in a straight or angle version. These valves offer the luxury of an adjustment to the venting rate meaning quicker venting for harder to heat areas and slower for overheated areas. Also consider changing your often overlooked main line vent valves while you are at it. Both these brand named valves can be found at Sid Harvey's or ordered through your local Heating Contractor. And yes we do have steam heat in the mountains of northeastern California..........dave
  • bob young
    bob young Member Posts: 2,177
    steam air valves
    gorton or maid-o-mist jacobus are my valves of choice .
  • Jerry, those main vents are vital
    to proper steam distribution at ounce pressures. Measure the length and diameter of your steam mains and tell us what vents are on them.
