D'mand vs. Grunfos recirc
Jerry_15
Member Posts: 379
Oh heck, live it up. You already went through the trouble of putting in a return line, and probably insulated the hell out of everything. Put in a little teeny pump and let it blow. The difference in price will make up heat loss/electric cost of use in 20 years maybe, but the warranties are only for a year. How much more technology do you really want to deal with on an everyday basis? My hard-drive is full
Hey guys how have you been?
Any opinions on this? Ran a recirc line, but rather not use due to more standby loss. This is my own house,long ranch. Can't decide which would work for me..TIA!0 -
D'mand...
... has my vote. Their system uses demand activation via wireless remote, motion sensor or just a door bell type switch to start the pump. It runs until the water just warms. No other system keeps the run time so low. So, other systems will get similar water savings, but not energy savings. Good insulation is important. I understand activating it before use could be a hiccup, but folks have learned to use light switches without much trouble :~) http://www.gothotwater.com/
Yours, Larry0 -
Good Morning
The Dmand pump will do a nice job for you. However, if you ran a return line, why not use the Taco 006PNP? The Dmand pump is a good candidate for a retrofit using the cold water supply as the return line. Excellent way of installing a recirculation system when a running a return line is just not possible. For your reference, I have attached information on the Taco 006 PNP.
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
joemat@taco-hvac.com0 -
D'Mand is like...
...primary/secondary for plumbing. If doable, pipe a 3/4" PEX loop in the basement, connected to the water heater, with the D'mand pump on the return side. Get the primary loop as close as possible to the fixture groups, and then use multi-port Tees to feed the hot water fixtures directly. If you keep the runs to the fixtures short -- less than 10 feet if possible, you'll run about a cup of water down the drain before the hot water gets there. You can enable the pump with either a push button switch or a motion sensor, whichever makes sense. You can give me a buss at the office if you need some info, or check the Uponor website, product showroom section. Good luck, Bob...
JMB0 -
Exactly!
John, I just piped a large house this way using one inch PEX with short half inch branches,(all insulated). Using demand control, it should give really fast service. It's nice to see you mention it. Sounds like you've been talking to Gary Klein ;~)
Yours, Larry0 -
California Energy Commission
That group certainly does its research. Some of the numbers Gary showed were absolutely amazing, especially when he showed that a copper run and branch system actually outperforms a home run system on the second use, since the water and the pipes are already hot. Never would have looked at it from that point of view. Duh!
JMB0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 984 Plumbing
- 389 Solar
