stuck vent valve
Eric Snyder
Member Posts: 1
Hi All,
I have oil-fired steam heat in my house. The vent on one of the mains has been periodically sticking open. A little tap will get it to close. Rather than running down to the basement when I hear a loud hiss, I decided to replace it.
Well, I took progressively longer wrenches and I am unable to break the vent or the nipple free. I tried using some "liquid wrench" on the nipple to main connection, to no avail. I hesistate to use a long cheater bar because I don't want to break the main or the nipple or knock the pipes loose from their hangars, etc.
Any tricks of the trade to break loose the old rusted connections?
Thanks! Eric
Thanks! Eric
Heat around the base of the fitting. You want the female threads to expand, and this usually breaks it free. Mapp gas usually gets things hot enough for me...
TimJust a guy running some pipes.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
