Taco 00R
Weezbo
Weezbo Member Posts: 6,231
  • Rob_25
    Rob_25 Member Posts: 20
    Taco 00R
    Has anyone used a Taco 00R circulator? Is there any difference between the 00R and an 008? The tech support I got at Taco didn't seem too sure other than the 00R having an LED when running.
    Thanks, Rob.
  • Rob_25
    That's the way I saw it. I just wondered if there was some benefit to using the 00R in a radiant application.
    Rob.
  • Joe Mattiello
    Joe Mattiello Member Posts: 740
    00R synonymous with radiant
    The Taco 00R was specifically designed for the radiant market. The theory behind differentiating the 00R from the 00 series was making this pump, because of its performance curve synonymous with radiant systems. In most cases people in general have a difficult time sizing a circulator for their proposed radiant system design. The 00R curve satisfies most design criteria without having to select a pump specifically for that design.
    Joe Mattiello
    Taco Comfort Solutions
  • An alternative
    might be to check out the UPS 15-58FC (SuperBrute). You have a greater degree of performance based upon the 3-speed capability of the pump. Additionally, medium speed is roughly equivalent to the 00R, giving you the ability to tune the system up or down if you need to.
    Check out the attached literature for curves.
  • Rob_36
    Rob_36 Member Posts: 16
    Thanks for the suggestion. To explain a little further, I have 6) Taco 007 circulators in my system. I would like to replace one of them to get more flow through some radiant loops. Other than looking out of place with the other Tacos the super brute would seem to be a good option. Would it mount to the same webstone flange as the 007 was on?
    Thanks, Rob.
  • brucewo1b
    brucewo1b Member Posts: 638
    Yes but you may
    have to turn the flanges 90 degrees
  • You can specify the model that mates up
    with the same flange orientation as the 007. It is a UPS 15-58FRC. The R stands for rotated flange, so it will mate up with your installed flanges.
  • Jed_2
    Jed_2 Member Posts: 781
    It's a 008, Joe, with IFC (NM)
